Thank you. Does the 5 way 2” filter wheel front plate fit the 7 way 36mm filter wheel and if so then can it be bought separately?
Are there any other solutions?
I’m trying to mate the 36mm filter wheel with my telescope but the telescope side opening is causing vignetting once an adaptor is used. A number of 36mm filter wheels I’ve seen from other manufacturers have either m48 or m54 telescope side opening but won’t work with my ASIAir.
Many thanks
Robert
