I'm new user of an AsiAir Mini. In order to run AsiAir softawe, I've to select the AsiAir wifi. But, by the way, I lost the connection to internet. So how it's possible to verify if there are update? And how to install it? The question concern AsiAir equipment, not application PC.
Thanks for your help
Dominique
How to update AsiAir Mini?
The update is embedded in the ASIAir app on your iOS or Android device. When you connect to the Air it will automatically update for you. You can verify in the mini that version 2.1.1 is installed which is the latest.
Thanks for your Quick answer. I use the android application. This Android is either connected to Asiair mini via its wifi, (without internet), either to wifi of my box (and internet). So it can't verify if Asiair is up to date. Perhaps something miss me...
- Edited
ddaniel84 So it can't verify if Asiair is up to date.
The ASIAIR firmware is a payload that comes with the ASIAIR app. The app will pester you to download the firmware it needs if it finds the firmware in the ASIAIR device to be too old.
If your ASIAIR app on the tablet says it is running v 2.1.1, then your firmware is also current. The last time it changed was a couple of months ago.
Good. Thanks a lot.
- Edited
Hi Chen, as I come back to home, I check the version. It's V2.1-10.74 (2 of march 2023). No allusion to any new version 2.1.1
I use the Android version.
How to get this V2.1.1?
I check it on zwo site, and on PLAY Store.
Bonzer2u ok. Fine. Thanks for your Quick answer. Do you know when is planed the next release? I am waiting impatiently for the support of Canon R50.
