I was a bit confused with all the information i found, so please, if something in my thoughts is wrong, let me know.
My setup:
ZWO ASI 120mm mini for guiding (3.76um pixels)
270fl guide scope (a bit longer)
714mm main scope
2600MC Pro for imaging
AM5 mount
Asiair pro
So lets sum all facts i gathered sofar.
Pixel scale of guiding camera - its simply telling us, how much arc seconds are per pixel on the camera.
Pixel scale can be calculated by roughly 206/<focal length>*<pixel size of camera>
In my case, for my ZWO 120mm mini and 270 guide scope - 206 / 270 * 3.76 = 2.8687 = +- 2.9 arcseconds per pixel
Now, guiding is made by pulses, in asiair case, one pulse each guiding frame - frame is simply happening each guiding camera refresh. If you have guiding camera on expoasure 1sec, then it happens each 1sec.
Sidereal movement (guiding) is 15arcsec per sec. Now, to successfully guide, without any backlash, you want to tell the mount to slow down, or fasten up. but slow only up to 1x to not change the direction of the motor.
so the mount goes one direction 15 + n15 or slows 15 - n15. Normally, in asiair you can choose the N between 0.25, 0.5, 0.75 and 1. AM5 mount have basic value of 0.5x and according to forums it cannot be changed (have the rig offline now)
So with 0.5X guiding, you are telling mount that it can use up to 7.5arcsec / s to correct the movement. Lets assume its set to 0.5X
The guiding step
If you open the PHD log (accessible in asiair when connected to PC) in PHD log viewer, you will see calibration circle wide 25 pixels, with small circles on RA/DEC axis. each circle, is one calibration step.
For example with GS 1000ms you will jump 7.5arcsecs = 7.5/2.9 = 2.6 pixels. that is roughly 10x each direction, which is considered as sweet spot. More is not needed, and just slowing the process, less than 9 steps is affecting quality.
Maximum RA/DEC duration
This value is telling you, what is MAXIMUM (can be used less) pulse that can be done in ONE FRAME to compensate any error. So, if you use 150ms, it can use any number up to 150ms each frame to compensate any error.
I did some calculations on my mount (my serial number test report), to get maximum error that my particular serial number can have, and its 0.12 arcsec per second. Thats pretty nice number, and so we CAN theoreticly set the max duration to very low number to compensate - like, at 150ms it would be 0.150x 7.5 = 1.125 per one correction. Thats more than 10x more then the error.
BUT, we are compensating not only mount errors, but also wind, loose cables that are winking in the air, atmosphere and so. So in not ideal life you need more than that. So setting around 400-800 is fine for 0.5-1s frames.
RA DEC aggr - its percentage of how strong the pulse is actually released to the gear. From many discussions i manage to get that for AM5 45-65 is used. "because of strain wave gear"
So now my humble questions:
- why is generally suggested faster updates (0.5-1s frames) for strain wave gears ?
- why is aggr setting for RA / DEC aggr for AM5 mounts offen suggested at 35-65 ? On what base is this? Is there some official suggestion on this case?
- If there will be some bigger problem to compensate, and maximum of the duration pulse will be used, what will happen if the compensation for one frame*aggr will be longer then the frame itself? will it overlap to another frame and cause some problems? - some say that with longer max steps they have oblong stars
If i understood anything wrong, please tell me, and i will be happy for any answer from more experienced colleagues Clear skies
