You can test whether or not you need to turn DST off manually for your Android Tablet running the ASIAIR App. It would be appear for some they don't but for others they do.
Make sure the Android Tablet has its location information set as you would normally - time (DST on), date, location.
When you first turn on the ASIAIR Plus and connect to it with the ASIAIR App - check the lat, long information. Make sure it is right. Then, when you get into it, go to the Mount/Telescope settings and check everything there is correct. See what happens when you press "Sync to Mount".
If the time isn't correct after pressing Sync to Mount - i.e. it is showing DST time and not the normal non-DST time - then you know the Android Tablet needs to be set up with the DST set manually and turned off (so you Android Tablet will be on non-DST).
Also - double check your settings for your Plan etc after an App update has happened (as well as a firmware update). It could be that setting got changed, or added, that will need to be changed.
