Hi,
I received my ASI174MM mini a few weeks ago. It was long to test it with my OAG because the weather was really not compliant.
Last night, I needed to rotate the camera because the larger sensor dimension was not in the same plan as the right ascension. It was installed perpendicular instead. According to the label on the 1-1/4" barrel, the label should be written on the same axis as the larger sensor dimension. This morning, I put aluminium tape to mark the exact position of the camera related to OAG before dismantled it. After inspection, the label are really perpendicular to the sensor main axis. I don't know if this camera came from a bad batch or not.
By chance, I owned also an ASI290MM mini for another setup so was able to inspect it. The label on the barrel coincide with the CMOS sensor main axis like my ASI6200MM.
Is there a way to rotate the internal motherboard (including CMOS sensor) to permit the main axis to be parallel to the label? I see two tiny Philip screws in the front but not sure if there are two other holes perpendicular to them.
Maybe it seems picky but I prefer when thing are well done. And please, don't tell me that the guiding calibration process could take care of it...I know. It might be a labelling defective process BUT I paid the big price for this camera so I want what I've paid for.
Regards,
Yves
