Hello, I just did an upgrade of all the softwares so i'm not really sure if it comes from the new 1.3.7 release.
Here is my setup:
- The mount is connected to a mini pc running nina/phd2 using usb. ASI Mount Ascom version is 6.5.14.0
- It is also connected to another pc running stellarium using network (the mount is connected to my home router). ASI Mount Ascom version here is 6.5.12.0
(phd2 -> 2.6.11dev6, nina -> 2.3 HF1).
I witnessed at least 2 times that while guiding, the mount synchronizes to another RA/DEC coordinates. It does not affect the guiding, and it appears to do so at a random time. I noted the last "jump", the coordinates went from (15:16:22, +56°14'54" the object location) to (15:15:53, +60°04'18" nothing here).
Do you have any suggestion on where to start to look at ? I'm a bit worried by this behaviour since I leave my gear running at night and would not be there to avoid a crash. The ascom logs shows nothing weird AFAIK except for the coordinate jumps.
Thanks !
