I have ZWO ASiAir Plus recently and Celestron AVX. I am trying to connect ASiAir Plus but connection is unstable. I tried different Baud rates it didn't worked. Then I changed cable still it didn't worked. How it can be resolved. I did everything including alignment process on AVX also.
What's the issue & how to resolve it?
With the pro I connect the usb ti HC without issues
So you say connection is unstable. Does this mean it connects sometimes or not at all?
Is the AVX new?
Have you updated the mount and hand controller firmware since you bought the mount?
How do you have ALL your equipment connected and powered?
    I use a power tank with AVX and a battery for Asiair when on field
    I use the power supply 220-12v when at home, one for each device
    Usb cable of a couple of meters with “gold” connector directly from HC to AAP
      Is the AVX new?
        andybutt Yes. Before firmware update it was 1-2 sec. After 10-15 sec. Then it is lost.
        Yes. I updated firmware
        stevesp Mine USB cable is with "gold" connector directly from HC to AAPlus
        andybutt thanks buddy. It's new mount with Mini USB B to USB 2.0
        If I am not wrong then it's for ASIAIR PRO. It had the issue and AVX users needed to overwrite Pro OS. ZWO said they had resolved this issue in ASIAIR Plus. That's why I decided to go for Plus.
        Other person who is talking to me from ZWO USA said update to 2.1.1 10.74 but on Play store they still have 2.1 10.74 I am expecting his reply.
        If he recommend to update OS then I'll go for it. Till then 🤞
          andybutt Play store has 2.1, App Store has 2.1.1
          Yes, they had to fix a bug in their iOS app that was apparently not present in the Android version.
          The firmware payload for ASIAIR 2.1.1 did not change from ASIAIR 2.1 (notice that it does not nag you to update firmware when you update from 2.1 to 2.1.1).
          Since it is firmware related, if a mount does not work with 2.1, it will still not work with 2.1.1.
          10 months later
          Finally we had to talk to Celestron. They asked to update firmware and it got connected
          Write a Reply...
