andrew_l However, I recently deleted and reloaded the APP on my iPad. Now it won’t connect to the ASIair.
Go to iOS Settings (the gray gear icon).
In Settings window, scroll the left panel all the way down until you see the Apps section (where the permissions of all your apps reside). You should see ASIAIR there, alphabetically sorted. Tap on ASIAIR.
On the right panel, ASIAIR access privileges should show up.
You need to give access to Local Network, and to Location services (at least at the "While Using" level).
It accesses a server in China, so we now also get nuisance ads in the ASIAIR splash screen -- you can decide based on those two whether you want to continue using ASIAIR.
