HI THERE I'M HAVING PROBLEMS WITH MY FAN PON MY 183MC ZWO CAMERE I'M USING ASILIVE STACK IT WORKS WHEN PLUGED OUT BUT AS SOON AS I PLUG IT IN IT STOPS WORK, DOES ANYONE KNOW WHY THIS IS HAPPENING ITS SOOO ANOYING, I WOULD BE GREAT FUL IN ANY HELP
Mirrorgirl The fan will run when you connect the USB cable and power supply, then stops if you click 'connect' in ASIStudio, and will run again if you turn on the cooling.
