ASIMount@ZWO thanks!
ASI Mount app v1.4 ia available for iOS
ASIMount@ZWO I just tried ASIMount v1.4 and it reports that my HC (v2.4) and AM5 (1.3.7) are both up to date. How do I get AM5 v1.3.9?
ASIMount@ZWO Thanks! Much appriciated.
tbhausen Sorry, it's my fault to note you AM5's firmware is v1.3.9.
The latest firmware for AM5 is v1.3.7 which you already upgraded.
v1.3.9 is for AM3.
Sorry again.
- Edited
ASIMount@ZWO no problem… Thank you!
Edit: but if you ship my ASI2600MC Duo soon I’ll feel much better
tbhausen We've already delivered in order. Thank you for your support.
- Edited
ASIMount@ZWO I know this isn't the place (I was being lighthearted), but that order (#61247) still shows as "Processing" to me.
I've had someone comment on a video that they went to update the AM5 via the ASI Mount app, but on their "iPad mini" there is no AMH Management option under the mount icon which leads to the firmware etc. Any feedback?
Gleann Could you tell me the iPad info about the system and OS. We will check it later.
ASIMount@ZWO unfortunatly it's from someone else who has made a comment on my youtube video that shows how to do the AM5 firmware update, I have no other information than that sorry. I did respond to them to check they are on the latest version of the app as I see there was a new version 10 days ago.
Gleann The latest version mostly for AM3 Bluetooth control. Before upgrade AM5's firmware, users should update HC firmware. The latest HC firmware is v2.4. Then they can get the latest AM5's firmware v1.3.7.
Tips: Update firmware via HC should connect AM5 and your smart device to your router which access the internet.
ASIMount@ZWO yeah, the problem was the person couldn't even get to the part of the app to even update the HC. But as a follow up, they have reported trying again a few times and the AMH Management finally appeared and they eventually got it updated:
Gleann Thank you. That's nice the "AMH Management" appeared and I'll deliver the issuse to our colleague to locate the problem.
- Edited
ASIMount@ZWO I don't understand why you still cannot filter objects under the search window like in ASI Air. It would seem like such a simple fix/addition.
felixcortez I don't understand why you still cannot filter objects under the search window like in ASI Air.
Sorry about that. I will record your requirements into the requirements pool.
Thank you.
ASIMount@ZWO thank you. It would make a big difference in planning objects from my desk instead of at night, in the driveway.
Hi, Will be an Android version released soon ?
LionelC Coming soon. Thank you for your support and patience
If I do not own AsiAir can I manually enter RA/Dec coordinates through the ASI Mount app instead? If this feature is currently not supported then will it be added to ASI Mount app in the future? Thank you.
- Edited
Proud owner of the AM3 since today. Absolutely great and beautiful mount! Waiting for clear skies ;-).
Is there an easy way to automatically link the actual FoV (= mount position) with the center of the screen ("Lock" function in SkySafari)?
I like to click a button or have an option that aligns the blue and the red FoV indicators automatically. Thanks!
