I'm setting up the EAF on my Edge HD 8" for the first time.
Thank you1 Jerry
jsg 1 Usually set the 0 positions when the focuser tube totally retracted. 2 Need to adjust it if using a narrowband filter. you can check the image in preview mode. 3 Change the rotation direction of EAF shaft 4 Yes.
Tech@ZWO
Thanks!
