  • Fan vibration testing for 2600, 533 and 183 cooled cameras.
Tech@ZWO
The ASI585MC "Pro" that I bought about a month has the mounting bolts directly threaded into the fan body.
What this means is that the bolt directly touches both the fan body and the camera back plate. That directly couples the vibration from the fan to the camera body, and in turn, to the OTA. This was the problem with the ASI2600/6200 fan.
Will you also be offering a kit to isolate the fan vibration away from the ASI585's body?
Tech@ZWO
This doesn't work with 294, there is not enough room for those nuts between fan and cooler blades. I had to reverse it and also use conical bolt heads which sunk into fan holes partly, and nuts are outside the camera case. Otherwise my solution is similar than w7way:s.
Write a Reply...
