Is C/2023 P1 (NISHIMURA) Available in ASI AIR SKY ATLAS? At least I cant find yet.
hi, i am adding manually from stellarium according to the time i will shoot.
Tayfun Thank you
Hi, how can you add it manually? Should there not be a real time comet database update in V2.1?? Will Asiair track the comet? Ralf
Use this link: https://theskylive.com/c2023p1-info to find its exact and if using the AAP then manually enter the RA and DEC go to.
