Good evening,
I use my ZWO setup with LRGB & SHO filters. In NINA, you could register the shifting of the EAF between the different filters. Like this, when you change filter, the EAF motor shift with the shift table value and the focus is OK.
It is could be interesting to have an automatic procedure to make the focus on the same target with the different filters (but not the same time) in order to register precisely the focus difference. Like this, when we make a filter change, the focus could be done automatically. It could be very useful in live stacking.
When we make the plan, it could be interesting too. With this shifting, we could avoid the autofocus step or start the autofocus in a better position after a filter change.
Thank you for your help,
Kaelig
