Well.....Isn't it true that 1.25-inch filter thread is M28?
I have a few filters that I use with visual observing
They screw into the front end of an eyepiece which is 1.25"
I took one of them out today and measured it - and it measures 28.3mm
I then tried it on the end of the ASI-120 camera housing
It was too small
The ID of the camera housing measures as a little over 29mm
However - when I look at the drawing from ZWO for the camera
They show a small end-cap on the end of the camera housing
And they call that end cap: 28.5 * .6
So perhaps I should just go ahead and purchase an M28 adapter and see if it works
