u152I28P Hurry up with your mono 585 version, because if you wait too long, no one will buy it...
If it is configured like their color version, no informed person would be buying a monochrome version of the IMX585 from ZWO anyway.
ZWO switches on the HCG mode at a fixed gain, and the gain is set at such a ridiculously high value (25.2 dB) that the dynamic range suffers.
QHYCCD and Touptek have better control of HCG -- the ToupTek in fact has two completely different profiles, one with HCG off, and the other with HCG on; it is like having two different cameras. Both of the companies also have some form of HDR (high dynamic range) mode, which compensates for the 585's low electron well. The ToupTek cooler also has a ∆T of 40º to 45º (Celsius scale), while the ZWO 585MC is only 35ºC.
If you wish to remain in the ZWO ecosystem, get a ASI533MM instead. If you want a monochrome 585, get a QHYCCD one, or a ToupTek one. And there will likely be more choices before long, too. (With Touptek's AstroStation/StellarVita, you will be able to choose any brand camera.)
Tick, tick, tick,...
