Hi,
has anybody had this problem as well?
I use an AM5, TS CFAPO90 with 0.8 reducer (focal lenght 432mm), ASI 2600MM, ASIAIR PLUS, no counter weight (less than 10 kg)
guiding camera at separate 160mm guide scope: ASI 462 MC with L filter
I constantly have the problem that within 1 hour before MF the DEC axis is lost (star lost .... mass changed). As a result ASIAIR selects obviously another guide star and stabilizes, though the image is shifted. It looks as if the telescope moves South by a constant amount (typical 5% ... 10% of FOV) and stays then constant. This may happen several times. An example ist shown in the figure showing two ghost images. North is to the left.... I have a lot more examples.
https://ibb.co/7RtMmn6
Before that failure and AFTER MF everything is fine, images are at their suggested coordinates (Autorun, Plan).
In the following I put sections of the logs. The PHD2 parts clearly show, that ASIAIR guiding tries hard to shift the telescope north immediately before, but it fails. It looks as if the guide star moves out of the box.... S/N of the ASI462MC is not the problem. I suspect a gear issue... Any comments and replies, ZWO too..
Log enabled at 2023/09/26 19:53:22
2023/09/26 19:53:22 [Autorun|Begin] ruchba Start
2023/09/26 19:53:22 Target RA:20h30m45s DEC:+49°1'31"
2023/09/26 19:53:22 Shooting 10 light frames, exposure 900.0s Bin2
2023/09/26 19:53:22 Start Tracking
2023/09/26 19:53:22 [Guide] Stop Guiding
2023/09/26 19:53:22 [AutoFocus|Begin] Run AF before Autorun start, exposure 3.0s Bin1, temperature 21.9℃
2023/09/26 19:53:22 Find Focus Star
2023/09/26 19:53:31 Find Focus Star: detect and calculate star size 2.4 , EAF position 9324
2023/09/26 19:53:31 Find Focus Star: finding appropriate stars star size 2.4
2023/09/26 19:53:50 Find Focus Star: detect and calculate star size 12.2 , EAF position 10824
2023/09/26 19:53:50 Calculate V-Curve
2023/09/26 19:53:58 Calculate V-Curve: detect and calculate star size 12.7 , EAF position 10824
2023/09/26 19:54:08 Calculate V-Curve: detect and calculate star size 11.2 , EAF position 10624
2023/09/26 19:54:18 Calculate V-Curve: detect and calculate star size 9.2 , EAF position 10424
2023/09/26 19:54:27 Calculate V-Curve: detect and calculate star size 7.3 , EAF position 10224
2023/09/26 19:54:37 Calculate V-Curve: detect and calculate star size 6.0 , EAF position 10024
2023/09/26 19:54:47 Calculate V-Curve: detect and calculate star size 4.5 , EAF position 9824
2023/09/26 19:54:57 Calculate V-Curve: detect and calculate star size 2.7 , EAF position 9424
2023/09/26 19:55:06 Calculate V-Curve: detect and calculate star size 2.4 , EAF position 9224
2023/09/26 19:55:16 Calculate V-Curve: detect and calculate star size 2.7 , EAF position 9024
2023/09/26 19:55:26 Calculate V-Curve: detect and calculate star size 3.6 , EAF position 8824
2023/09/26 19:55:35 Calculate V-Curve: detect and calculate star size 4.7 , EAF position 8624
2023/09/26 19:55:45 Calculate V-Curve: detect and calculate star size 6.5 , EAF position 8424
2023/09/26 19:55:55 Find Focus Point
2023/09/26 19:56:03 Calculate Focus Point: detect and calculate star size 3.7 , EAF position 9605
2023/09/26 19:56:12 Calculate Focus Point: detect and calculate star size 3.3 , EAF position 9505
2023/09/26 19:56:22 Calculate Focus Point: detect and calculate star size 2.9 , EAF position 9405
2023/09/26 19:56:31 Calculate Focus Point: detect and calculate star size 2.6 , EAF position 9305
2023/09/26 19:56:40 Calculate Focus Point: detect and calculate star size 2.4 , EAF position 9205
2023/09/26 19:56:40 Auto focus succeeded, the focused position is 9205
2023/09/26 19:56:40 [AutoFocus|End] Auto focus succeeded
2023/09/26 19:56:42 [Guide] ReSelect Guide star
2023/09/26 19:56:43 [Guide] Start Guiding
2023/09/26 19:56:44 [Guide] Guide Settle
2023/09/26 19:56:47 [Guide] Settle Done
2023/09/26 19:56:47 Exposure 900.0s image 1#
2023/09/26 20:05:43 Stop Autorun Manually
2023/09/26 20:05:43 [Autorun|End] Pause Autorun
Log disabled at 2023/09/26 20:05:43
Log enabled at 2023/09/26 20:05:55
2023/09/26 20:05:55 [Autorun|Begin] ruchba Start
2023/09/26 20:05:55 Target RA:20h30m51s DEC:+49°1'31"
2023/09/26 20:05:55 Shooting 10 light frames, exposure 900.0s Bin2
2023/09/26 20:05:55 Start Tracking
2023/09/26 20:05:55 [Guide] Stop Guiding
2023/09/26 20:05:55 [AutoFocus|Begin] Run AF before Autorun start, exposure 3.0s Bin1, temperature 21.4℃
2023/09/26 20:05:55 Find Focus Star
2023/09/26 20:06:04 Find Focus Star: detect and calculate star size 2.4 , EAF position 9205
2023/09/26 20:06:04 Find Focus Star: finding appropriate stars star size 2.4
2023/09/26 20:06:24 Find Focus Star: detect and calculate star size 11.5 , EAF position 10705
2023/09/26 20:06:24 Calculate V-Curve
2023/09/26 20:06:33 Calculate V-Curve: detect and calculate star size 12.2 , EAF position 10705
2023/09/26 20:06:42 Calculate V-Curve: detect and calculate star size 10.0 , EAF position 10505
2023/09/26 20:06:53 Calculate V-Curve: detect and calculate star size 9.2 , EAF position 10305
2023/09/26 20:07:03 Calculate V-Curve: detect and calculate star size 7.2 , EAF position 10105
2023/09/26 20:07:13 Calculate V-Curve: detect and calculate star size 6.2 , EAF position 9905
2023/09/26 20:07:23 Calculate V-Curve: detect and calculate star size 4.7 , EAF position 9705
2023/09/26 20:07:33 Calculate V-Curve: detect and calculate star size 2.8 , EAF position 9305
2023/09/26 20:07:43 Calculate V-Curve: detect and calculate star size 2.4 , EAF position 9105
2023/09/26 20:07:53 Calculate V-Curve: detect and calculate star size 2.6 , EAF position 8905
2023/09/26 20:08:02 Calculate V-Curve: detect and calculate star size 3.4 , EAF position 8705
2023/09/26 20:08:13 Calculate V-Curve: detect and calculate star size 4.5 , EAF position 8505
2023/09/26 20:08:23 Calculate V-Curve: detect and calculate star size 6.0 , EAF position 8305
2023/09/26 20:08:33 Calculate V-Curve: detect and calculate star size 7.5 , EAF position 8105
2023/09/26 20:08:43 Find Focus Point
2023/09/26 20:08:52 Calculate Focus Point: detect and calculate star size 4.1 , EAF position 9528
2023/09/26 20:09:01 Calculate Focus Point: detect and calculate star size 3.6 , EAF position 9428
2023/09/26 20:09:11 Calculate Focus Point: detect and calculate star size 3.2 , EAF position 9328
2023/09/26 20:09:20 Calculate Focus Point: detect and calculate star size 2.8 , EAF position 9228
2023/09/26 20:09:29 Calculate Focus Point: detect and calculate star size 2.5 , EAF position 9128
2023/09/26 20:09:29 Auto focus succeeded, the focused position is 9128
2023/09/26 20:09:30 [AutoFocus|End] Auto focus succeeded
2023/09/26 20:09:31 [Guide] ReSelect Guide star
2023/09/26 20:09:32 [Guide] Start Guiding
2023/09/26 20:09:33 [Guide] Guide Settle
2023/09/26 20:09:37 [Guide] Settle Done
2023/09/26 20:09:37 Exposure 900.0s image 1#
2023/09/26 20:24:38 [Guide] Dither
2023/09/26 20:24:38 [Guide] Dither Settle
2023/09/26 20:24:48 [Guide] Settle Done
2023/09/26 20:24:48 Exposure 900.0s image 2#
2023/09/26 20:39:49 [Guide] Dither
2023/09/26 20:39:49 [Guide] Dither Settle
2023/09/26 20:40:14 [Guide] Settle Done
2023/09/26 20:40:14 Exposure 900.0s image 3#
2023/09/26 20:55:16 [Guide] Dither
2023/09/26 20:55:16 [Guide] Dither Settle
2023/09/26 20:55:30 [Guide] Settle Done
2023/09/26 20:55:30 Exposure 900.0s image 4#
2023/09/26 20:57:03 [Guide] Guide star lost
twice: Guide Star loss (mass changed, c.f. below in PHD2 section,
2023/09/26 20:57:04 [Guide] ReSelect Guide star
2023/09/26 20:57:05 [Guide] Start Guiding
2023/09/26 21:06:49 [Guide] Guide star lost
happened 32 min and 19 min before MF, two ghost (shifted pictures)
2023/09/26 21:06:51 [Guide] ReSelect Guide star
2023/09/26 21:06:51 [Guide] Start Guiding
2023/09/26 21:10:32 [Guide] Dither
2023/09/26 21:10:32 [Guide] Dither Settle
2023/09/26 21:10:58 [Guide] Settle Done
2023/09/26 21:10:58 [Guide] Stop Guiding
2023/09/26 21:10:58 Stop Tracking
2023/09/26 21:10:58 [Meridian Flip|Begin] Wait 14min5s to Meridian Flip
2023/09/26 21:25:03 Meridian Flip 1# Start
2023/09/26 21:25:03 [AutoCenter|Begin] Auto-Center 1#
2023/09/26 21:25:03 Mount slews to target position: RA:20h30m51s DEC:+49°1'31"
2023/09/26 21:25:34 Exposure 5.0s
2023/09/26 21:25:40 Plate Solve
2023/09/26 21:25:42 Solve succeeded: RA:20h33m11s DEC:+49°22'35" Angle = 89.962, Star number = 626
2023/09/26 21:25:42 [AutoCenter|End] Too far from center, distance = 24%(0.51769°)
2023/09/26 21:25:44 [AutoCenter|Begin] Auto-Center 2#
2023/09/26 21:25:44 Mount slews to target position: RA:20h30m51s DEC:+49°1'31"
2023/09/26 21:25:45 Exposure 5.0s
2023/09/26 21:25:51 Plate Solve
2023/09/26 21:25:54 Solve succeeded: RA:20h30m52s DEC:+49°1'43" Angle = 89.8319, Star number = 638
2023/09/26 21:25:54 [AutoCenter|End] The target is centered
2023/09/26 21:25:54 [Meridian Flip|End] Meridian Flip succeeded
2023/09/26 21:25:54 Start Tracking
2023/09/26 21:25:54 Wait for Mount Settle
2023/09/26 21:25:59 Start Tracking
2023/09/26 21:25:59 [AutoFocus|Begin] Run AF after Auto Meridian filpped, exposure 3.0s Bin1, temperature 19.6℃
2023/09/26 21:25:59 Find Focus Star
2023/09/26 21:26:07 Find Focus Star: detect and calculate star size 2.4 , EAF position 9128
2023/09/26 21:26:08 Find Focus Star: finding appropriate stars star size 2.4
2023/09/26 21:26:27 Find Focus Star: detect and calculate star size 12.5 , EAF position 10628
2023/09/26 21:26:27 Calculate V-Curve
2023/09/26 21:26:35 Calculate V-Curve: detect and calculate star size 13.2 , EAF position 10628
2023/09/26 21:26:45 Calculate V-Curve: detect and calculate star size 10.7 , EAF position 10428
2023/09/26 21:26:55 Calculate V-Curve: detect and calculate star size 9.1 , EAF position 10228
2023/09/26 21:27:05 Calculate V-Curve: detect and calculate star size 7.4 , EAF position 10028
2023/09/26 21:27:14 Calculate V-Curve: detect and calculate star size 5.8 , EAF position 9828
2023/09/26 21:27:24 Calculate V-Curve: detect and calculate star size 4.5 , EAF position 9628
2023/09/26 21:27:34 Calculate V-Curve: detect and calculate star size 3.5 , EAF position 9428
2023/09/26 21:27:44 Calculate V-Curve: detect and calculate star size 2.7 , EAF position 9228
2023/09/26 21:27:54 Calculate V-Curve: detect and calculate star size 2.4 , EAF position 9028
2023/09/26 21:28:04 Calculate V-Curve: detect and calculate star size 2.7 , EAF position 8828
2023/09/26 21:28:14 Calculate V-Curve: detect and calculate star size 3.8 , EAF position 8628
2023/09/26 21:28:24 Calculate V-Curve: detect and calculate star size 4.8 , EAF position 8428
2023/09/26 21:28:34 Calculate V-Curve: detect and calculate star size 6.4 , EAF position 8228
2023/09/26 21:28:44 Find Focus Point
2023/09/26 21:28:52 Calculate Focus Point: detect and calculate star size 4.2 , EAF position 9468
2023/09/26 21:29:01 Calculate Focus Point: detect and calculate star size 3.7 , EAF position 9368
2023/09/26 21:29:11 Calculate Focus Point: detect and calculate star size 3.1 , EAF position 9268
2023/09/26 21:29:20 Calculate Focus Point: detect and calculate star size 2.8 , EAF position 9168
2023/09/26 21:29:29 Calculate Focus Point: detect and calculate star size 2.5 , EAF position 9068
2023/09/26 21:29:29 Auto focus succeeded, the focused position is 9068
2023/09/26 21:29:30 [AutoFocus|End] Auto focus succeeded
2023/09/26 21:29:31 [Guide] ReSelect Guide star
2023/09/26 21:29:32 [Guide] Start Calibrating
2023/09/26 21:30:51 [Guide] Calibrate Success
2023/09/26 21:30:51 [Guide] Guide Settle
2023/09/26 21:31:03 [Guide] Settle Done
2023/09/26 21:31:03 Exposure 900.0s image 5#
2023/09/26 21:46:05 [Guide] Dither
2023/09/26 21:46:05 [Guide] Dither Settle
2023/09/26 21:46:14 [Guide] Settle Done
2023/09/26 21:46:14 Exposure 900.0s image 6#
2023/09/26 21:46:22 Stop Autorun Manually
2023/09/26 21:46:23 [Autorun|End] Pause Autorun
Log disabled at 2023/09/26 21:46:23
c.f. image 4 before MF : 2 additional „ghost“ images
PHD2: log file messages,
before problem occurs; DEC corrections increase, but cannot compensate DEC issue, star moves obviously out of box , star lost......
after selecting new guide star: neutral guiding until next case....,, Image shifted though
AFTER MF: everything is normal, image is not shiftet any more, corresponds to chosen image RA/DEC image coordinates when starting AUTORUN or PLAN
- jump:
5646,2834.626,"Mount",0.228,0.407,0.088,-0.458,0.000,-0.183,0,,46,N,,,3397,41.00,0
5647,2835.149,"Mount",0.401,0.448,0.238,-0.550,0.075,-0.220,27,W,55,N,,,3604,42.16,0
5648,2835.658,"Mount",0.439,0.388,0.293,-0.505,0.095,-0.202,34,W,51,N,,,3459,41.27,0
5649,2836.131,"Mount",0.256,0.446,0.102,-0.503,0.035,-0.201,13,W,50,N,,,3476,41.46,0
5650,2836.631,"Mount",0.095,0.398,-0.037,-0.408,0.000,-0.163,0,,41,N,,,3428,41.17,0
5651,2837.131,"Mount",0.209,0.517,0.034,-0.556,0.000,-0.222,0,,56,N,,,3432,41.23,0
5652,2837.639,"Mount",0.221,0.600,0.019,-0.639,0.000,-0.255,0,,64,N,,,3458,41.35,0
5653,2838.128,"Mount",0.217,0.484,0.052,-0.528,0.000,-0.211,0,,53,N,,,3386,40.91,0
5654,2838.647,"Mount",0.126,0.400,-0.007,-0.420,0.000,-0.168,0,,42,N,,,3547,41.90,0
5655,2839.071,"Mount",0.006,-0.024,0.013,0.021,0.000,0.000,0,,0,,,,3485,41.50,0
5656,2839.570,"Mount",-0.133,-0.176,-0.071,0.209,0.000,0.000,0,,0,,,,3578,42.09,0
5657,2840.077,"Mount",-0.090,-0.210,-0.018,0.227,0.000,0.000,0,,0,,,,3443,41.26,0
5658,2840.569,"Mount",-0.020,-0.092,0.010,0.094,0.000,0.000,0,,0,,,,3499,41.64,0
5659,2841.077,"Mount",0.071,-0.061,0.087,0.036,0.000,0.000,0,,0,,,,3465,41.44,0
5660,2841.606,"Mount",0.174,0.186,0.106,-0.231,0.033,-0.092,12,W,23,N,,,3421,41.10,0
5661,2842.166,"Mount",0.396,0.521,0.210,-0.619,0.067,-0.247,24,W,62,N,,,3492,41.48,0
5662,2842.686,"Mount",0.481,0.746,0.219,-0.858,0.071,-0.343,25,W,86,N,,,3468,41.35,0
5663,2843.216,"Mount",0.592,1.146,0.198,-1.273,0.065,-0.509,23,W,127,N,,,3567,42.01,0
5664,2843.723,"Mount",0.579,1.440,0.092,-1.549,0.000,-0.620,0,,150,N,,,3455,41.33,0
5665,2844.264,"Mount",0.599,1.924,-0.043,-2.015,0.000,-0.806,0,,150,N,,,3552,41.90,0
5666,2844.708,"Mount",0.907,2.522,0.059,-2.679,0.000,-1.071,0,,150,N,,,3534,41.75,0
5667,2845.251,"Mount",2.098,5.058,0.384,-5.459,0.121,-2.184,43,W,150,N,,,3541,41.75,0
5668,2845.805,"Mount",4.590,11.102,0.828,-11.978,0.265,-4.791,94,W,150,N,,,2304,33.49,0
5669,2846.009,"DROP",,,,,,,,,,,,,696,18.22,6,"Star lost - mass changed"
5670,2846.506,"DROP",,,,,,,,,,,,,111,7.28,6,"Star lost - mass changed"
5671,2847.008,"DROP",,,,,,,,,,,,,206,9.89,6,"Star lost - mass changed"
5672,2847.538,"DROP",,,,,,,,,,,,,232,10.77,6,"Star lost - mass changed"
5673,2848.009,"DROP",,,,,,,,,,,,,241,10.98,6,"Star lost - mass changed"
5674,2848.527,"DROP",,,,,,,,,,,,,222,10.54,6,"Star lost - mass changed"
5675,2849.012,"DROP",,,,,,,,,,,,,232,10.77,6,"Star lost - mass changed"
5676,2849.538,"DROP",,,,,,,,,,,,,211,10.03,6,"Star lost - mass changed"
5677,2850.007,"DROP",,,,,,,,,,,,,215,10.37,6,"Star lost - mass changed"
5678,2850.510,"DROP",,,,,,,,,,,,,229,10.70,6,"Star lost - mass changed"
Guiding Ends at 2023-09-26 20:57:03
Guiding Begins at 2023-09-26 20:57:05
Dither = both axes, Dither scale = 1.000, Image noise reduction = none, Guide-frame time lapse = 0, Server enabled
Pixel scale = 3.74 arc-sec/px, Binning = 1, Focal length = 160 mm
Search region = 50 px, Star mass tolerance = 50.0%
Equipment Profile =
Camera = ZWO ASI462MC, gain = 116, full size = 1936 x 1096, no dark, no defect map, pixel size = unspecified
Exposure = 500 ms
Mount = ZWO AM5, connected, guiding enabled, xAngle = -18.5, xRate = 2.807, yAngle = -108.9, yRate = 3.995, parity = ?/?,
X guide algorithm = Hysteresis, Hysteresis = 0.100, Aggression = 0.350, Minimum move = 0.100
Y guide algorithm = Resist Switch, Minimum move = 0.100 Aggression = 40% FastSwitch = enabled
Backlash comp = disabled, pulse = 0 ms
Calibration step = phdlab_placeholder, Max RA duration = 150, Max DEC duration = 150, DEC guide mode = Auto
RA Guide Speed = Unknown, Dec Guide Speed = Unknown, Cal Dec = 49.0, Last Cal Issue = None, Timestamp = Unknown
Dec = 49.0 deg, Hour angle = -0.44 hr, Pier side = West, Rotator pos = N/A
Lock position = 1130.984, 683.561, Star position = 1131.291, 683.774, HFD = 6.27 px
Frame,Time,mount,dx,dy,RARawDistance,DECRawDistance,RAGuideDistance,DECGuideDistance,RADuration,RADirection,DECDuration,DECDirection,XStep,YStep,StarMass,SNR,ErrorCode
INFO: SETTLING STATE CHANGE, Settling started
1,0.572,"Mount",0.223,0.416,0.079,-0.465,0.000,-0.186,0,,47,N,,,3444,41.26,0 from here: normal guiding
2,1.130,"Mount",0.205,0.411,0.063,-0.454,0.000,-0.182,0,,46,N,,,3492,41.57,0
3,1.593,"Mount",-0.013,0.494,-0.169,-0.465,-0.053,-0.186,19,E,47,N,,,3544,41.87,0
4,2.142,"Mount",-0.042,0.438,-0.179,-0.403,-0.058,-0.161,21,E,40,N,,,3397,41.00,0
5,2.571,"Mount",0.198,0.420,0.055,-0.461,0.000,-0.184,0,,46,N,,,3406,41.03,0
6,3.081,"Mount",0.191,0.175,0.125,-0.226,0.040,-0.090,14,W,23,N,,,3461,41.29,0
INFO: SETTLING STATE CHANGE, Settling complete
7,3.561,"Mount",0.099,0.344,-0.015,-0.358,0.000,-0.143,0,,36,N,,,3775,43.25,0
8,4.109,"Mount",0.005,0.255,-0.076,-0.244,0.000,-0.097,0,,24,N,,,3489,41.60,0
9,4.563,"Mount",0.122,0.220,0.046,-0.247,0.000,-0.099,0,,25,N,,,3415,41.12,0
10,5.095,"Mount",-0.032,0.091,-0.059,-0.076,0.000,0.000,0,,0,,,,3490,41.46,0
11,5.575,"Mount",0.306,0.104,0.257,-0.193,0.081,-0.077,29,W,19,N,,,3510,41.63,0
12,6.110,"Mount",0.202,-0.159,0.242,0.088,0.079,0.000,28,W,0,,,,3600,42.25,0
13,6.555,"Mount",0.128,-0.254,0.202,0.202,0.067,0.000,24,W,0,,,,3405,40.80,0
14,7.032,"Mount",-0.031,-0.104,0.004,0.108,0.000,0.000,0,,0,,,,3555,41.94,0
15,7.526,"Mount",-0.037,-0.261,0.047,0.260,0.000,0.000,0,,0,,,,3553,41.75,0
16,8.058,"Mount",-0.067,-0.160,-0.012,0.173,0.000,0.000,0,,0,,,,3448,41.10,0
17,8.555,"Mount",-0.115,-0.028,-0.100,0.062,-0.032,0.000,11,E,0,,,,3579,42.07,0
18,9.083,"Mount",-0.156,-0.003,-0.147,0.051,-0.047,0.000,17,E,0,,,,3698,42.77,0
19,9.541,"Mount",-0.071,-0.054,-0.050,0.073,0.000,0.000,0,,0,,,,3546,41.87,0
20,10.096,"Mount",-0.060,-0.110,-0.022,0.124,0.000,0.049,0,,12,S,,,3626,42.32,0
21,10.557,"Mount",-0.060,-0.139,-0.013,0.150,0.000,0.060,0,,15,S,,,3705,42.81,0
22,11.066,"Mount",0.008,-0.105,0.041,0.097,0.000,0.000,0,,0,,,,3640,42.44,0
23,11.537,"Mount",0.006,-0.079,0.031,0.073,0.000,0.000,0,,0,,,,3595,42.20,0
24,12.092,"Mount",0.044,-0.175,0.097,0.153,0.000,0.061,0,,15,S,,,3515,41.40,0
- jump:
1136,568.135,"Mount",-0.005,-0.040,0.008,0.039,0.000,0.000,0,,0,,,,3692,42.70,0
1137,568.691,"Mount",0.071,-0.031,0.078,0.008,0.000,0.000,0,,0,,,,3657,42.48,0
1138,569.135,"Mount",-0.029,0.026,-0.036,-0.016,0.000,0.000,0,,0,,,,3770,43.09,0
1139,569.716,"Mount",-0.065,0.169,-0.115,-0.140,-0.036,-0.056,13,E,14,N,,,3689,42.71,0
1140,570.165,"Mount",-0.151,0.162,-0.194,-0.107,-0.062,-0.043,22,E,11,N,,,3612,42.26,0
1141,570.652,"Mount",0.157,0.047,0.134,-0.094,0.040,0.000,14,W,0,,,,3622,42.26,0
1142,571.159,"Mount",0.148,0.078,0.116,-0.120,0.038,-0.048,13,W,12,N,,,3862,43.63,0
1143,571.696,"Mount",0.036,0.263,-0.049,-0.261,0.000,-0.105,0,,26,N,,,3662,42.59,0
1144,572.148,"Mount",-0.017,0.113,-0.053,-0.102,0.000,-0.041,0,,10,N,,,3679,42.59,0
1145,572.697,"Mount",-0.119,0.159,-0.163,-0.114,-0.051,-0.046,18,E,11,N,,,3714,42.89,0
1146,573.171,"Mount",-0.062,0.232,-0.132,-0.201,-0.043,-0.081,15,E,20,N,,,3802,43.37,0
1147,573.703,"Mount",0.086,0.185,0.022,-0.202,0.000,-0.081,0,,20,N,,,3749,43.09,0
1148,574.177,"Mount",0.206,0.205,0.130,-0.259,0.041,-0.104,15,W,26,N,,,3830,43.59,0
1149,574.728,"Mount",0.246,0.300,0.139,-0.361,0.045,-0.144,16,W,36,N,,,3731,42.98,0
1150,575.166,"Mount",0.107,0.191,0.041,-0.215,0.000,-0.086,0,,22,N,,,3869,43.72,0
1151,575.708,"Mount",0.030,0.171,-0.026,-0.171,0.000,-0.069,0,,17,N,,,3812,43.44,0
1152,576.199,"Mount",0.302,0.244,0.208,-0.326,0.066,-0.130,23,W,33,N,,,3815,43.46,0
1153,576.796,"Mount",0.488,0.617,0.267,-0.737,0.086,-0.295,31,W,74,N,,,3779,43.18,0
1154,577.215,"Mount",0.259,0.774,0.000,-0.817,0.000,-0.327,0,,82,N,,,3796,43.26,0
1155,577.748,"Mount",0.299,1.009,-0.036,-1.052,0.000,-0.421,0,,105,N,,,3693,42.66,0
1156,578.308,"Mount",0.323,1.421,-0.144,-1.451,-0.046,-0.580,16,E,145,N,,,3783,43.13,0
1157,578.783,"Mount",1.276,3.908,-0.030,-4.111,0.000,-1.644,0,,150,N,,,1910,30.14,0
1158,579.080,"DROP",,,,,,,,,,,,,246,11.09,6,"Star lost - mass changed"
1159,579.581,"DROP",,,,,,,,,,,,,243,11.02,6,"Star lost - mass changed"
1160,580.089,"DROP",,,,,,,,,,,,,245,11.07,6,"Star lost - mass changed"
1161,580.584,"DROP",,,,,,,,,,,,,254,11.27,6,"Star lost - mass changed"
1162,581.119,"DROP",,,,,,,,,,,,,245,11.07,6,"Star lost - mass changed"
1163,581.583,"DROP",,,,,,,,,,,,,252,11.22,6,"Star lost - mass changed"
1164,582.120,"DROP",,,,,,,,,,,,,246,11.09,6,"Star lost - mass changed"
1165,582.582,"DROP",,,,,,,,,,,,,252,11.22,6,"Star lost - mass changed"
1166,583.084,"DROP",,,,,,,,,,,,,257,11.34,6,"Star lost - mass changed"
1167,583.582,"DROP",,,,,,,,,,,,,242,11.00,6,"Star lost - mass changed"
Guiding Ends at 2023-09-26 21:06:49
Guiding Begins at 2023-09-26 21:06:52
Equipment Profile =
Exposure = 500 ms
Dec = 49.0 deg, Hour angle = -0.28 hr, Pier side = West, Rotator pos = N/A
Lock position = 853.148, 552.833, Star position = 853.365, 552.819, HFD = 5.32 px
1,0.532,"Mount",-0.003,-0.014,0.002,0.014,0.000,0.000,0,,0,,,,2509,35.15,0
2,1.031,"Mount",0.031,-0.106,0.063,0.091,0.000,0.000,0,,0,,,,2522,35.23,0
3,1.552,"Mount",0.044,0.028,0.033,-0.040,0.000,0.000,0,,0,,,,2626,35.99,0
4,2.031,"Mount",-0.000,-0.036,0.011,0.034,0.000,0.000,0,,0,,,,2537,35.34,0
5,2.556,"Mount",-0.041,-0.035,-0.028,0.045,0.000,0.000,0,,0,,,,2540,35.37,0
6,3.054,"Mount",0.080,-0.033,0.087,0.006,0.000,0.000,0,,0,,,,2654,36.14,0
7,3.539,"Mount",-0.107,-0.044,-0.087,0.075,0.000,0.000,0,,0,,,,2545,35.39,0
8,4.057,"Mount",-0.045,0.061,-0.062,-0.044,0.000,0.000,0,,0,,,,2449,34.65,0
9,4.528,"Mount",-0.070,-0.116,-0.030,0.132,0.000,0.000,0,,0,,,,2549,35.39,0
10,5.072,"Mount",0.063,0.086,0.032,-0.101,0.000,0.000,0,,0,,,,2484,34.89,0
11,5.549,"Mount",-0.137,-0.072,-0.107,0.111,-0.034,0.000,12,E,0,,,,2627,35.97,0
12,6.050,"Mount",0.113,0.016,0.102,-0.051,0.031,0.000,11,W,0,,,,2512,35.20,0
13,6.561,"Mount",0.328,0.098,0.280,-0.195,0.089,0.000,32,W,0,,,,2446,34.66,0
14,7.117,"Mount",0.321,-0.076,0.329,-0.027,0.107,0.000,38,W,0,,,,2554,35.48,0
15,7.551,"Mount",0.117,-0.022,0.118,-0.015,0.041,0.000,15,W,0,,,,2567,35.44,0
16,8.035,"Mount",0.019,0.018,0.012,-0.022,0.000,0.000,0,,0,,,,2581,35.56,0
17,8.535,"Mount",-0.020,0.102,-0.051,-0.091,0.000,0.000,0,,0,,,,2535,35.25,0
18,9.083,"Mount",-0.008,0.039,-0.020,-0.034,0.000,0.000,0,,0,,,,2624,35.94,0
19,9.535,"Mount",0.056,0.040,0.040,-0.055,0.000,0.000,0,,0,,,,2599,35.70,0
20,10.083,"Mount",0.063,-0.001,0.060,-0.019,0.000,0.000,0,,0,,,,2608,35.82,0
21,10.547,"Mount",-0.105,0.033,-0.110,0.001,-0.035,0.000,12,E,0,,,,2513,35.19,0
22,11.046,"Mount",0.024,0.064,0.003,-0.068,0.000,0.000,0,,0,,,,2531,35.20,0
23,11.555,"Mount",0.197,0.100,0.155,-0.156,0.049,0.000,17,W,0,,,,2653,36.09,0
24,12.104,"Mount",0.212,0.048,0.186,-0.112,0.060,0.000,21,W,0,,,,2591,35.70,0
25,12.541,"Mount",0.056,0.059,0.034,-0.074,0.000,0.000,0,,0,,,,2539,35.29,0
26,13.060,"Mount",0.030,0.037,0.017,-0.044,0.000,0.000,0,,0,,,,2549,35.42,0
27,13.536,"Mount",-0.015,0.075,-0.038,-0.066,0.000,0.000,0,,0,,,,2575,35.55,0
28,14.056,"Mount",0.023,0.065,0.001,-0.069,0.000,0.000,0,,0,,,,2603,35.71,0
29,14.542,"Mount",0.021,0.102,-0.013,-0.104,0.000,-0.042,0,,10,N,,,2502,34.99,0
30,15.045,"Mount",-0.072,0.056,-0.086,-0.031,0.000,0.000,0,,0,,,,2536,35.26,0
31,15.549,"Mount",-0.072,-0.009,-0.065,0.031,0.000,0.000,0,,0,,,,2590,35.62,0
