Hi, apart from some nights where I am making setup changes which require the equipment to be disconnected and reconnected in software as changes are made, in some instances I am using the 2600MC Pro with a narrowband filter. I have a ZWO 7 X 36mm filter wheel and OAG fitted to this camera so that the configuration and optical spacing matches my ASI2600MM camera and I will eventually change to a second ASI 2600MM Pro when funds allow. Having optically and mechanically identical setups allows me to move the cameras between my two telescopes easily.
To get successful automated focus runs using the ASI2600MC Pro with the narrowband filters instead of the clear glass filter requires a difference in focus settings which is managed with a change of user profile in the imaging software (Voyager) I am able to automate the change of profile but changing profiles requires the setup to be disconnected, meaning any time that I do that the camera has to be re-cooled. Depending on what I am shooting this may happen a number of times in a night.
The other issue I have run into was what looks like a memory leak on one of my two setups where slightly more memory was used with each image shot, until an out of memory error would occur and result in shots failing. When that occurred, disconnecting and reconnecting the camera would resolve it (Again in Voyager I am able to automate the error detection and setup disconnect/reconnect cycle) but again, would require re-cooling the camera any time this occurred.
