When I connect to my Seestar I can, of course, see it on the list of wifi objects I can connect with. However, I cannot see the Seestar under the Bluetooth menu. Why?
What is the purpose of the Bluetooth..not explained in the incredibly small and poor manual.
    Fid Bluetooth function can assist mobile phone pairing with Seestar,haha
    Why does Seestar have to have Bluetooth connections even if we don't use it? Why can I not turn it off and still use the Seestar. My Seestar will not run unless the WIFI and Bluetooth are both checked on. If I could turn off Bluetooth and Seestar still worked I could use a emulator on my PC. Which for myself and others would be a much better option. Gigger screen and all.
      scopesnc Maybe it uses Bluetooth to transfer images to your phone? Some other functions?
      A lot laptops, and even desktops, come with the ability to connect to devices via Bluetooth as well as using Wi-Fi. Can you not connect your laptop/desktop to Seestar Wi-Fi as well as have your Bluetooth turned on? Might be able to then use the Seestar App in BlueStacks (for example) to use with the Seestar?
      It is only in Potrait Mode, though. Unless ZWO have enabled Landscape mode with it?
      The purpose of turning on Bluetooth is to find devices and guide connections to hotspots.
      Write a Reply...
