scopesnc Maybe it uses Bluetooth to transfer images to your phone? Some other functions?
A lot laptops, and even desktops, come with the ability to connect to devices via Bluetooth as well as using Wi-Fi. Can you not connect your laptop/desktop to Seestar Wi-Fi as well as have your Bluetooth turned on? Might be able to then use the Seestar App in BlueStacks (for example) to use with the Seestar?
It is only in Potrait Mode, though. Unless ZWO have enabled Landscape mode with it?
