The ZWO Seestar worked perfectly upon arrival; and I thought it quite remarkable how easily it found targets.
A few days later with an ensuing update (mandated) it has become completely useless. It will never find a target, and will not even resolve a target when it is in view. Even syncing when in view does not resolve this. It constantly complains of being "out of level" even after several successful levelings using the app. It is level on the ground, it just constantly complains it's not. Even switching between "star gazing" mode and "lunar" mode will register a complaint that it is not level by 4 or 5 degrees. Get it level (under 1 degree) switch it back to "star gazing mode" and it says "not level" by 4 or 5 degrees again.
It has not been dropped or bumped. I have set it on an array of different tripods with no success. I have recalibrated numerous times, deleted the app and started again, nothing fixes it.
How do you perform a factory reset on the unit - is that even possible?
