mhb1089
Hello! I never attach my GTO Keypad, hence, I would suggest you also should remove yours as I also do ( when working with ASIAIR+) since I did never pay any attention or even care, how or if it will work, when the GTO Keypad is attached,
since I have the GTO Keypad, but to be honest, I did never ever use it..
All I do is...
I only connect the ASIAIR+ via the USB2 port from ASIAIR+ to the GTOCP4 USB PORT and then trun on the GTOCP4
and ASIAIR+ also, slecet the correct mount type and BAUDE-RATE in ASIAIR and then send a GOTO COMMAND or ,ove the mount via ASIAIR MOUNT COMMANDS, from the ASIAIR+ to the GTOCP4 to move the mount to any direction, then I plate solve via the ASIAIR and that sends SYNC COMMANDS ( SYNC TO MOUNT) to the GTOCP4, and then GOTO''s are 99.9% correctly performed..
I am not sure if same would work with your mount also, does your mount has any ENCODERS ?? my mount MACH1GTO does not have any ENCODERS !!
And to your question, if the PARKING 3 Position remains, and in my case YES, when I connect the GTOCP4 to the ASIAIR
and then the next day or week later, I want to work via ASCOM ( PC ) then, the PARKING 3 position is still recognized from the ASCOM DRIVER!!
Regards
Martin
