Originally, after locking the azimuth axis "wings" stick out almost perpendicular to the mount.
It made it a bit difficult for me to manage the cables. I found information in the video review that you should lift them slightly up when they are in the unlocked position, and then when locking them again they will hide deeper. I did that, but I see it was a mistake.
The right "wing" must now fully retract to block the axis. I move it towards me so that it almost touches the mount. When set to the pole, this will pose a problem because it may interfere with the azimuth adjustment knob.
Can it be set back to how it originally was?
Edit: wingnuts must be locked, then You can lift them up and change their position, case closed🙂
