Hi all, I use an Nikon Z6 II on a Asiair Plus 32.
The Nikon is connected to the Asiair with an USB cale and the N3 2.5 mm cable for the comand.
When I do 60s exposures the Nikon swith to bulb mode instead of 60s exposure.
And during a preview or a live I stack less than 15 pictures in half an hour and sometimes there that tells me something like there a connection problem between Asiair and Nikon and I must restart the live (sorry I haven't the message, it's showed to fast).
The Asiair has got the latest firmware like the Nikon and I've tried two USB cables.
Have you any idea of the problem ?
All the best.
JC
    Ok thanks.
    I'll try BULB mode before launching Asiair.
    All others parameters are ok. Mode M, RAW, quality, space on SD and Asiair, APN battery, power saving mode and noise reduction.
    I will tell you tomorrow if it's work.
    All the best
    Tech@ZWO
    It doesn't work.
    Here's the exact message : "Exposure failed, please check if the Shutter Release Cable in connected propertly."
    But the picture I get is good and well exposed.
    Mode M, autofocus off, BULB Mode is on, Raw L no compression no JPEG, space on SD and Asiair, APN battery Ok, no noise reduction, no saving mode.
    Sometimes the APN shows "PC connected", and sometimes "RAW, exposure, time etc" like it wasn't connected.
    When I launch the shooting, you've first a countdown during 60s, clic clac, then 60s without countdown, clic clac, the countdown sometimes or the message.
    The first image I get is ok.
    Thanks for your help
      Neoprog
      J’ai aussi un Nikon Z6 II. Après 2 ans de haute lutte ( check sur le forum) , ils ont enfin fini par le rendre utilisable sur l’Asiair. Ça n’a pas été sans peine !
      Je vais re-tester ça demain pour voir si j’arrive à reproduire l’erreur que tu rencontres.
      J’ai trouvé, il faut déchocher dans les paramètres de l’appareil photo EXP with Shutter Release Cable. C’est tout…
      Damned !
      Write a Reply...
