Anyone using this scope on the AM5? I am not sure if the weight is 32 lbs without the support rings. If the AM5 can support this telescope + camera, guide scope and some spacers I am going to get it.
Thanks, Jerry
jsg AM5 supports 13kg without counterweight or 20kg with counterweight of 5kg. It shows Sharpstar SCA260 v2 is 15kg, so you should pay attention about the total weight and absolutely use counterweight.
OK, thanks.
