tantalusthief
I will be using N.I.N.A for my polar alignment at first. I say at first because I also purchased not only the AM5 but an ASIAIR and I want to test out the mount using my mini pc and Nina. Then once I get the mount working and tested out, I will then throw ASIAIR into the mix and see how that goes.
Good luck and if you need help setting up N.I.N.A, I would suggest you look at the user called Patriot Astro as he has quite a few youtube videos on N.I.N.A and has helped me out greatly.
Good luck and clear skies,
David J.
