Hello, since the last update of the S50 the problems are varied. It doesn't track well, sometimes not even at 10". I calibrate and balance the telescope perfectly. I check it several times, and yet the problem often persists. I use a Skywatcher equatorial wedge, which is very good quality and has never given me any problems, but since the last update, the telescope's orientation gets out of adjustment every now and then. And the fixing screws are tight. Finally, I aligned it perfectly the last time, placed a guide laser parallel to the Seestar optical tube, and asked it to point the telescope at Polaris. My goal was to see how accurate the orientation was. Well, to my surprise, the telescope started moving and finally pointed at the ground, at about 40° inclination. I thought I had done something wrong and repeated the operation three times, after of course exiting the app and restarting the telescope. And nothing, always the same. Can you give me a solution? Can you fix all these errors? Honestly, I'm half a minute away from selling the Seestar S50 and buying a new device. that it doesn't fail so much
