Hi ! I’m probably not the only one who encountered this issue : my AM5 azimuth stop nut has some play and I want to tighten it. How did I noticed it ? Simple : when I put my finger on the stop and tighten one of the az screw, I can feel the stop moving a bit. Obviously it’s slightly unscrewed and it needs to be tightened.
Problem, I can’t find a way to access to the stop.
It seems that I need to disassemble the lower part of the mount and then I should be able to access the az stop, but I’m not sure and if so it may not be possible without a special tool.
A picture's worth a thousand words一画胜千言 :
And yes, I can see there’s a hole in the stop nut, and I suppose it’s there to tighten the stop screw but the mount design doesn’t allow me to introduce any tool in it.
Hopefully someone will help with this. Someone from @ASIMount@ZWO maybe ?
