Hi Tech Support,
I cannot tell you the model and backfocus of the two lenses. I bought my 120mm second hand, and one was the original cctv lens..or I thought.. and the second was bought by me to get a 120 degree FOV.
I tested both lenses on a QHY5II camera, and I received similar results. So, I am confident the problem is with the backfocus or lens.
Looking at my configuration in the photo above, can you recommend a ZWO lense and spacer that will work for me? My goal is to use the camera as an All Sky Camera, so a 100 degree FOV or larger is preferred. Please no plastic lenses, as it gets very sunny and relatively hot here in the summer.
Clear Skies and Sincerely,
Paul
