Kevin_A Hi Kevin, thank you for the information. Zwo will hardly recognized why they changed, improvement? cost reduction with more prodution of a single product? difficulty to master the production of the 432s period stain wave? Nevertheless, as far as I understand reading through a lot of post (including the very instructive one of w7ay :-)), the key parameter is the PE rate in arcsec / sec, ie the slope of the PE curve. Assuming 14 arcsec peak to peak smooth pe curve it would mean 0.15 arcsec/sec max slope, let's take the double or even the triple for erratic PE curve you get 0.45arcsec/sec that you can compensate with a 61ms pulse every sec at 50% sidereal guiding. And that is achievable with PHD2 with 1sec. Following the same analysis, I changed everything on a small NEQ5 goto and I improved guiding significantly by increasing the guiding rate to 2 times / sec 0.5s exposures but OAG becomes difficult as there is not enough light for short exposures.
CS Frédéric
