Is it possible to charge the battery of the seestar while imaging? If so how?
wd4sel Seestar supports imaging while charging
So how do you do it? When I hooked up the power cord the camera stopped.
wd4sel Please ask if you have plugged the other end of the power cord into the computer. If it is a normal charger, this problem will not occur, but if the other end is plugged into the computer, it will not work.
Got it...thanks much
