Just to clarify, for this problem above ... on the iPhone 14, is the Settings > Cellular Data need to be toggled off or is it Settings > Seestar > Cellular Data togged off?
Jaymc turn off the cellular data from the control panel that you can swipe down from top right corner, the radio broadcast button should be greyed out (off). This is the only workaround that seems to solve the problem for me right now .
Также самая проблема на Xiomi Redmi Note 10s
Had the problem with scenery after the firmware update. I ended up invoking stargazing and once the telescope started rotating, I returned and invoked scenery. That worked for me and after I powered off and on, scenery mode continues working.
