Using Seestar v1.12.0 for android (latest available as this is being written).
Phone #1: (android 12) seestar app steadfastly refuses to believe that it has been granted bluetooth access, probably because that it is under "nearby devices" under settings on this phone.
Phone #2: (android 10) no problem with bluetooth, but wifi is super flaky. The S50 never shows up as an available connection. I can manually set one up with my S50's ssid and default password, then manually connect to that, but as soon as I try to get the scope to do anything, the connection drops and its back through the loop again.
A quick scan through the posts leads me to believe that the majority of you are using iphones. So, is the S50 really just an iphone device, or does the android lnterface actually work? If you are successfully using the android app, please post which hardware you are using, especially tablets, so I can get an idea of what actually works.
Thanks much,
J V
