@Kevin_A thank you so much for writing this, and suggesting the settings to be used as a starting point.
I just purchased a new iOptron HAE69C mount and it didn't really perform out of the box as expected. My first session the guiding was 0.60" on average, but was oscillating a lot between 0.35 and 2.20" for the duration of the 4hr session. I was using my FRA400 with the WO UniGuide 30mm guidescope, which is not a big/heavy load. Apparently, my settings were completely wrong. I set the calibration step to 8000 following advice from that blog page, and left the Max Ra and Dec Duration at 2000. I will try using the settings you listed and see how it goes.
Thank you again for taking the time to share all this good information.
