Folks -- I have been imaging with the 6200 OSC camera for a couple of years and often obtain images like those attached with a single wide band starting at the lower edge of the frame and extending upwards about 1/2 way.
I have attached two examples, one is after PIxinsight batch pre-processing with bias, dark, and flats applied but no post-processing other than background extraction and histogram stretching. The second image is stacked w/o flats (obviously :-) nor darks or bias in Deep Sky Stacker just to see if the band is an artifact of Pixinsight -- but it still appears. Note that I omitted dithering in these examples so perhaps that is contributing...I will reshoot next clear night but wanted to see if anyone has any ideas in the meantime...
The band is not super bright so I have marked it with the white oval in both images.
I did send some example images in to ZWO after originally getting it and seeing this but nothing unusual was found by their support.
Thanks for any suggestions! Charlie Wiecha
