Hello friends,
got an Canon R10 - how do i connect this nice present to my ASI AIR Plus? Or have i to wait to a new software release for my AA+?
regards, Gerhard
astromoose Thank you for your support, sorry to tell you that Canon R10 does not on the supported list of ASIAIR.
Same here. Would love to see the R10 being supported, please.
… R10 does work nicely with the ASIAIR :-). I had to enable something like ”allow capture without lens” in the custom menu.
Obs30 How were you avle to do it? I can take picture without my lense but it never connects to the asiair… everywhere I look it says that it is not compatible. You are my last hope! 😜
U1YS5Rn7 What finally worked were the RAW image settings. It has top be set to RAW, with HDR and compressions turned off. Also only RAW, not RAW & L or something like that.
The R10 works OK, but it is not an astrocamera!
Hi there, any update as of Sept 2025? Is the Canon R10 supported with the ASIAIR? Thanks
It already works! Follow the instructions on the ASIAIR screen by the letter! Get a good USB-C to USB-2 or USB-3 cable suitable for high data rates!
You need to turn off HDR mode(s). And only pick RAW as the data format, not C-RAW (RAW-C?) and not L !!! And also allow "taking images without a lens".
Then it works really nicely.
Yep. R10 support was added in v2.1.2 - FW 11.01 (see here: https://www.yuque.com/zwopkb/asiair/release-log).
Do what Obs30 said to do. More info here as well: https://www.yuque.com/zwopkb/asiair/dslr-ml-connections
