satch984 You can first use a leveling bubble meter to find a horizontal plane, then place the Seestar with the tripod removed on this plane. At this time, use a leveling bubble to place it on the Seestar to verify whether the Seestar is level. If the Seestar is not level at this time, Please check whether there is foreign matter at the bottom of the Seestar that affects the level of the Seestar.
