cubanvirgil Do you mean the USB port on the ASIAIR Plus can not recognize hard drive now?
Could you please do this to rule out the problem first?
1 Connect the USB drive to PC to see if it works
2 Connect other device to the USB port on ASIAIR Plus, do these ports work fine?
BTW, restart the ASIAIR Plus is also needed, thank you.
