What is the maximum tilt angle that it is safe to operate the Seestar at? Given that it doesn’t check for level in the latest software, does that means it’s safe to operate the Seestar at any tilt angle, or is their a maximum safe tilt angle.
tarbat In order to ensure accurate tracking and finding of celestial objects, it is recommended to ensure the level of the equipment during use.
tarbat Sorry for not making it clear, using the Seestar in a tilted state will not damage the parts, but it will make the Seestar in an unstable state, which poses certain risks. Officials do not recommend such use.
Thankyou, but that wasn't my question. At the tilt angle illustrated, the Seestar tracks perfectly accurately, with no problems. My question was whether it's safe to use the Seestar at this tilt angle? Is there a maximum safe tilt angle?
tarbat It is safe to use Seestar at this tilt angle, and you can boldly try new gameplay.
Are there latitude limits? Or is a tilt plate usable from the equator to the pole?
Please let me know if latitute 35° (meaning I have to set at 55° angle) is ok for EQ mode.
So setting the Seestar on an EQ wedge is ok?
So equatorial mode is possible must try?
