How can I access the master darks created by the Seestar in order to use them for offline stacking with Siril or other similar software?
Thanks
altazastro Seestar does not support exporting dark field files. Seestar will automatically process each frame of image.
They have long been visible in a folder name "DarkLibrary": what if I want to completely calibrate and process the raw files on an application like Astro Pixel Processor or Siril or PixInsight?
altazastro You don't need the darks for PixInsight, Siril, etc. as each LIGHT has already been calibrated with the appropriate master dark.
Yes, true, I understand.
Thanks to all.
