Dear Forum, I find various official / inofficial max voltage statemants on ZWO Products.
I am Running an ASIAIR Plus with Asi2600/2400 on an AM3 with Filter Wheel and Focusser.
My current power Supply gives 10 amps but under full load only about 11.7 Volts arrive at the gear. Power lines are short and adequate, it is just the power supply giving not too high of a voltage. It seems to run fine.
What do you think, can this damage something? On the other hand I have a 15V supply which gives exactly 15V when no load is connected.
Is it too much and there is a risk breaking something?
Best regards,
Stephan
    Sonixx 11V-14V are OK for ASI cameras, ASIAIR Plus and ASI Mounts.
    Thanks for your swift reply, so I better stay with my current power supply.
    Best regards,
    Stephan
    Write a Reply...
