This post is about how to access the ASIAIR Plus or Pro when you're NOT at home connected to your home network. Please look at the diagram carefully.
So recently I had a go at setting up a VPN Server on the travel router I have connected to the ASIAIR Plus (32GB) in order to connect to the ASIAIR remotely.
I managed to get it to work by setting up an OpenVPN Server on my travel router (GL.iNet MT-3000) and forwarding the required OpenVPN Server ports from my home router to the travel router.
I couldn't get Wireguard to work for some reason.
See the picture attached for an overview of my setup. If you would like details about any particular step - please let me know.
