This post is about how to access the ASIAIR Plus or Pro when you're NOT at home connected to your home network. Please look at the diagram carefully.
So recently I had a go at setting up a VPN Server on the travel router I have connected to the ASIAIR Plus (32GB) in order to connect to the ASIAIR remotely.
I managed to get it to work by setting up an OpenVPN Server on my travel router (GL.iNet MT-3000) and forwarding the required OpenVPN Server ports from my home router to the travel router.
I couldn't get Wireguard to work for some reason.
See the picture attached for an overview of my setup. If you would like details about any particular step - please let me know.
    Corsair I made it work using Tailscale. No port forwarding required. Just a Pc with tailscale open (or a raspberry pi if you have one) on the same local wifi where Asiair is connected.
      killerciao Ah. Yes, Tailscale is also available on the GL.iNET MT-3000 travel router so I don't think I would need to be running a PC. That is another option of VPN. https://docs.gl-inet.com/router/en/4/interface_guide/tailscale/
      I'll have to give it a go with my setup (as pictured) to see if I need to port forward from my main router to the travel router.
      I wouldn't need to port forward if:
      1. I had my ASIAIR directly connected to my Home router (and ran the VPN server on the Home router); or
      2. If the GL.iNet router was the main router.
      As it stands, with my current setup, I need to port forward from the Home router to the travel router in order for the VPN Server running on the travel router to connect to a remote device running the OpenVPN client app and allow connection to the ASIAIR via the ASIAIR App running on the remote device.
      4 months later
      Do you know if it can be done with a router with a 4G LTE SIM card? team up on the field, and connect from somewhere else? Is there any tutorial to do this?
        3 months later
        avpinedo apologies for late reply to this (and if you've sorted it already).
        If the router with the 4G LTE SIM card in it supports running a VPN - then yes. Just enable and configure the VPN on the 4G Router.
        If the 4G Router doesn't have support running a VPN then you would need to get separate travel router that does and use the method I showed in my original post.
        4 months later
        Corsair
        I’m currently fighting with the GL Inet router because my lack of net’s knowledge.
        I tried the same scheme that you have BUT i’m trying to connect using a 4G connection. The idea is to have my rig at the roof (11th floor) and control it from home (1st floor) so I believe I need a 4G/5G router.
        The idea is to use my MAC Book (runs Asiair app with no problems) connected to the GL Inet GL-XE300 (that uses a sim card for data). I tried but I failed, probably because I’m not sure what I’m doing. I tried Wireguard but failed. Using openVPN I can't see the minirouter from home but not the Asiair. Maybe because using a SIM card I have not a static public IP?
        Could you help me?
        Thanks in advance
        Write a Reply...
