Hi,
For a few days, I have recurring problems with my camera Asi2600MM Pro. First I observed small white bands on the whole image. Then a horizontal black band at the top of the image. And friday, I can't connect the filter wheel on the camera otherwise it no longer work and all image transfers from camera to pc failed. In the early night, some images were recorded but I find the signal very weak.
I specify that I tested with 3 different computers, 2 different boxes and power cable, 3 different USB3.0 cables. The image remains the same.
Have you ever had this kind of problem? if yes, have you found a solution that could help me please?
