When I started using 6200MM and 6200MC cameras recently with ASIAir Plus, I'm seeing a real lag time between image captures during a Autorun sequence. It will start off ok, with 1-2 images captured and saved to a USB stick inserted into the USB3 slot on the AA without delay.
But then a 1-2 minute period starts to occur between captures where nothing happens. The previous image has been saved but the next one in the sequence fails to start for around 2 minutes.
If I 'Pause' Autorun and then restart it right away, image capture starts up again and is good for 1-2 captures and then it falls back into this 2 minute or so lag between captures.
Has anyone seen this? Happens with both 6200MM and MC cameras and 2 different ASIAirs (a Pro and a Plus). So I don't think it is a h/w issue.
Any thoughts or suggestions??
