Where can I find that new feature?. Thanks
Update your Seestar app . This will add all the new features. Then when you connect Seestar it will automatically update software
H
I asked because I already updated the software, and I have access to the new options, but I can't find that specific one. Thanks.
When you run the Seestar App, from the front page and below the Solar widget, do you have two new buttons - "My Album" and "Deep Sky Stack" ? I also can't see the video stack option.
unixnut Yes, I see those two new options, but I don't see the video stack option
This is. What you should see. The tutorial menu has good instructions
I'm with the Ottokan on this. I updated, can see the DeepSky Stacking (and tried it). I don't however seem to be able to find the Video Stacking feature. I have videos (with and without Raw) saved on the SeeStar....still can't figure out how to start Video Stacking.
SHagler When you press "Deep Sky Stack" you should see folders with your sub images. Then you can select the one you want to stack.
LA3QMA When I go to Deep Sky Stack, I see: "Add Images" at the bottom. If I select that, I see the different deep sky sessions (including raw subs). I don't however see any of the videos that I took of Solar or Moon or Planets.
Same here, the stacked folder comes up, I can select the various files, but there is no way to start stacking. I watched a YouTube video tutorial and the Android version has a start button which does not appear on my iPhone.
first, when you capture the video, select RAW second, open My files, go to Seestar video, open the raw video and Stack video will apear.
Also in the app, you have a tiny/small icon on the top right with "Tutorial", there you will find the guide
У меня тоже невозможно найти для сложения в папке Солнце и Луну. Не понимаю что такое...
