Corsair there doesn't seem to be much difference between using the ASI120mm mini and the ASI220mm mini.
If you are going use multi-star guiding, there are many more important parameters than for single star guiding.
For one, you want really low read noise, so that you have sufficient dynamic range to include both bright and dim stars in the field. You also want the FOV to be as large as affordable. You want the frame rate to be as fast as possible. Etc, etc.
