  • What model Zwo Mini Guide Camera do I need for Guide Scope Orion 50mm?
What model Zwo Mini Guide Camera do I need for Guide Scope Orion 50mm? I have Quattro 250 ST Focal Length=800mm Diameter 200 and ZWO ASI 294MC Pro color cooled camera I also have ASIAIR Plus
    Corsair there doesn't seem to be much difference between using the ASI120mm mini and the ASI220mm mini.
    If you are going use multi-star guiding, there are many more important parameters than for single star guiding.
    For one, you want really low read noise, so that you have sufficient dynamic range to include both bright and dim stars in the field. You also want the FOV to be as large as affordable. You want the frame rate to be as fast as possible. Etc, etc.
    Corsair the pixels in the 120mm are smaller which is better but the 220 has a bigger field of view and better noise and higher gain settings if required. They used to sell a 290 with smaller pixels but they have discontinued it.
    My telescopes Focal Length is 800mm, I put the tube onto the mount in my room The Focal length is written on the Sky Watcher tube I didn't know my Focal Length before, but my Guide Scopes Orion is 50mm
    The weather right now is not going to be good, I have to wait a bit
    • w7ay replied to this.
      The Guide Camera ZWO ASI 220 MM MINI is very expensive hmm
        Lukasz Focal Length before, but my Guide Scopes Orion is 50mm
        That is not the focal length, it is the aperture of the OTA.
        Lukasz then get a asi120mm mini. Lots of people get good results using this guide camera.
        Write a Reply...
