Add a way to Name the EAF devices. I run 2, and I can switch back and forth between them easily enough, but it can be a real loss of time if I accidentally pick the wrong one and end up DEFOCUSSING instead of focussing.
Some simple naming, instead of both just showing up as EAF would be very helpful!
  • w7ay replied to this.
    applal Add a way to Name the EAF devices.
    You can rename them using ASIStudio.
    Write a Reply...
