As Chen said it has lots of high harmonics but a lot of the 288s period mounts have these rough curves and some guide well. So it seems in Asiair. You may get a worse mount the second time around if you order a replacement. Your mount has small PE but it is not smooth wheras higher end mounts have larger PE but smooth sinusoidal curves. I have found that with a rough high harmonic mount curve that these amateur mounts have, a lot of guiding advice does not work as well as with a smooth curve. In fact I can alter my durations and aggressions a lot and it changes nothing some nights. I am constantly testing and one definitive thing I have found is… asiair while convenient, is not good enough to tame a bad mount. You can give it all you have and nothing seems to control it when using asiair. Just make sure your Minmo is around no higher than 0.1px and disable backlash compensation unless it is really necessary.
    eyecon Yeah if it’s hit or miss with ZWO then it might not make a difference.
    It is a shame that ZWO is giving mounts that use strain wave gears a bad reputation.
    I have been using strain wave geared mounts since 2020, and have no problem with my four Harmonic Drive (TM) mounts.
      w7ay Kevin_A thanks for your feedback and advice…as this is my portable mount I’m not obsessing too much about guide errors just trying to get the best results possible as mentioned earlier. My iOptron CEM70 performs consistently at sub .4 arcsec rms. Unfortunately it weighs a ton 😂
      Out of curiously, 2hat would you consider to be a higher end strain wave mount?
      w7ay they really are just amateur mounts as they are very coarse in function! And the asiair implimentation of phd2 does not help. I upgraded all my guide scopes and it did only a little to help. When having perfect PA helps more than sharp stars one knows it is best to change ecosystems if you want the best and excellent images. For me right now I am ok with 0.5 to 0.6rms guiding averages as my biggest scope is a 644mm and I do not need 0.3rms guiding to get good round stars. But when I get around to building a skyshed with a bigger scope it will be with a premium mount and not Asiair controlling it! I will use the asiair ecosystem then on my AM5 when I go to the lake to do 15mm milkyway shots with this forgiving guided rig.
        Kevin_A I don’t own an Asiair and been only using phd2 so far. I just installed Metaguide which in theory could produce better guiding results since it’s using the camera’s video feed with a clever centroid averaging algorithm to track rather than discrete exposures. I have a feeling this type of guiding might be better suited for mounts with higher rates of change in their PE curve based on everything you experienced and w7ay has mathematically demonstrated on other threads.
          eyecon yes, the AM5 and asiair are not great but intended for fair guided portable use.
          I find it silly when users put C11 scopes on them…. Seriously? Haha It is like taking a dump truck to the racetrack or a Corvette off-roading!
          • w7ay replied to this.
            Kevin_A I assume by premium mount you’d be looking at a more traditional worm
            Gear mount? I haven’t done much research but at least what’s available here in Canada in terms of pure strain wave drive mounts seems to be the AM series from ZWO or the RST series from rainbow Astro. The RSTs are significantly more expensive the AM but I guess based on what w7ay explained on other posts, they seem to be better made and might have a better gearbox(?)
            Again for me, the AM5 is the portable rig which I’m using with my portable refractor setup. My 10” fast newt lives on the CEM70 and I have had no issues with guiding at all with this combo.
            It’s just always good to understand the equipment and try and squeeze as much performance as possible given the use case and price point.
              Kevin_A Seriously? Haha It is like taking a dump truck to the racetrack or a Corvette off-roading!
              So far, the largest payload I have put on the RST-135 and RST-135E is the FSQ-85 (dual saddle with side-by-side guide scope adding some 5 or 6 lbs).
              I have received my Mewlon 180C (waited a year for Tak ' manufacturing run) and will try that as a payload. But that is the absolute max I will put on it when weather allows. I have in the past without trouble used a C6A on an RST-135. The strain wave gear should have no problem slewing the Mewlon (even C11), but guiding could be a problem, we'll see. That being said, I plan on using the Mewlon unguided on the RST-135E, though -- the OTA is just for planetary (the encoder will keep the planet inside a 2.5" FOV).
              Hope I don't have to go to an RST-300 (way heavy for my taste, and I w'll need them to release an "E" version, in any case).
                eyecon I too am in Canada, near London Ontario. I have had worm gear mounts and I just got fed up with the huge weight carrying it and then balancing it. I would be looking at a RST135 maybe, as with a harmonic mount I do not have to perfectly balance it all the time as I switch up a lot between my 4 telescope rigs. I think iOptron HAE mounts are just a bit better than ZWO… but maybe not!
                  [unknown] I will probably go with a RST -135 next but I do not need it yet!
                  Is it work going to the 135E instead?
                    Kevin_A oh didn’t realize you were in Ontario, I’m in Burlington so not too far 🙂
                    Yeah being an iOptron mount user, I looked at the HAE series before pulling the trigger on the AM5 but they seemed a bit too expensive and heavy given their weight capacity…maybe I wasn’t comparing to the right models. Anyway I will try highspeed guiding with metaguide and see if I get better results on the AM5. Based on w7ay experience, the RST seems to be the way to go…for my portable rig use case I’m not sure the price point is justified. I think the RST maybe the way to go if it’s the only mount but at least based on my experience, the older worm gear tech offers a better cost to performance combination.
                      eyecon based on what w7ay explained on other posts, they seem to be better made and might have a better gearbox(?)
                      1. RainbowAstro uses the gears from Harmonic Drive LLC (USA, Germany and Japan plants), not Chinese copies.
                      2. RainbowAstro's parent company is RainbowRobotics, who have been building robotic arms for the industry for quite some time now. Before their strain wave gears, they had also been building observatory quality (read: humongous sized) mounts. RainbowAstro/RainbowRobotics actually share the Robotics Labs, and many faculty and researchers with University of Nevada (Las Vegas). RainbowRobotics CEO is an astrophotographer (eclipse chaser), and spun off RainbowAstro after collaborating on Harmonic Drive mounts with Hobym (another Korean mount manufacturer) before. As to precision, see this (watch it track the rim of the Sun):
                      https://www.youtube.com/watch?v=PzWc7adS-RY
                      1. you should see how clean their mount protocol commands is compared to ZWO's mount protocol. Engineers (retired long ago) like me try to spot bullshit by looking at things like that.
                      4) (tongue in cheek) they do the right thing with Local Sidereal Time. ZWO is using Local Time and Daylight Saving Time to figure out the timing for ASIAIR (and I presume their mounts). Now that the US has swithed to DST, we should see all sorts of Meridian Flip problems on this forum again.
                        w7ay really good to know, I expected the higher price point to be due to the better hardware components….they should really advertise this more of on their website/product pages. I saw that the rst uses servos rather than steppers so that to me indicated a general approach based higher end components.
                          eyecon yes, I am in Belmont between Port Stanley and London. I am in a Bortle 4 sky so it is nice to be out of the city lights. I am retired now so that helps with late nights! I built a new house 4 years ago in a dark place but neighbours are starting to ruin my skies so I am planning another move and that will include a real observatory…. So for now a portable mount is good but maybe a better harmonic drive will be still best in my future plans.
                          eyecon I think the lower end harmonic mounts use steppers so inexperienced users don’t destroy the mounts. The servos are much better and more precice these days.
                          Kevin_A Is it [worth] going to the 135E instead?
                          It all depends.
                          The Renishaw encoder in the 135E is only good to 2.5". So, if your plate scales need better than that (or you have nights where the "seeing" is better than about 2"), then the encoder will do you no good.
                          Think of it this way: gears are not precise enough for an arcsecond type precision. There are two ways to solve this -- one is to use the reference from a very precise encoder, and the other is to use the star themselves as even more precise reference points. Autoguiding is pretty much just using the stars as a very precise encoder (as long as the mount does not have glitches and respond properly to feedback pulses). In both cases, you establish a feedback loop to get the motors to point correctly again -- this is also why I prefer mounts that use servo motors instead of the (much) cheaper stepper motors that Chinese mounts (not just ZWO) use.
                          If you need better than 2.5" tracking, then you still need to autoguide anyway, and an encoder is wasted.
                          The reason I went from my initial two RST-135 to an RST-135E is that for a lot of my usage does not require high precision tracking (short focal length, planetary, solar [with FOA-60Q and a pair of Lunt filters [really heavy when double stacked!]).
                          I was so happy with the 135E (the peak error is 2.5", so the RMS error is more like 1.8") that I bought a second one, so that is how I eneded up with my current four RainbowAstro mounts.
                          My largest DSO scope only has 450mm focal length, so I can pretty much live with just the encoder alone. For planetary, you simply need to make sure the planet does not move out of the ROI. Ditto Solar.
                          So, for me at least, the 135E is definitely worth the upgrade from the 135 (you only live once, especially with the weather) -- wouldn't you pay an extra $200 to get rid of clouds just for one night? Fighting autoguiding error is just penny wise, pound foolish.
                          As to autoguiding, using 2 FPS guide camera,using the parameters that I had discussed here before (max step of less than 100, aggressiveness of less than 25%, overexpose by 10 dB over 12 stars), and a decent guide scope (either the 55mm BORG flourite, or the Vixen 55mm flourite), I can get a stable 0.25-0.35" total RMS tracking error (assuming calm winds) from the non-E. But you need to add the weight of a good guide scope, etc. Just like I was tired of counterweights and balancing, I also got tired of autoguiding.
                          Cheap mount + cheap guide scope is asking for trouble. If you cannot get a flat field, avoid using multi-star guiding.
                          On top of that, too many people try to autoguide away errors that are not caused by the mount (like wind), and end up with wild long term errors -- I simply don't understand why people have so much progblem autoguiding -- such people should just get a mount with an encoder. Autoguiding, like encoders, are to reduce mount errors, not wind, not field rotation. Stop tweaking the parameters to get short term error down (for the next 30 seconds). Compute what is needed, and use that setting for long term guiding.
                          ASIAIR also has a multi-star centroid problem, so you need to avoid using ASIAIR unless you restart autoguiding once every 30 minutes or so.
                            eyecon I saw that the rst uses servos rather than steppers so that to me indicated a general approach based higher end components.
                            My 20+ year old EM-11 mount uses servos. Of couse, Takahashi machining is smooth as silk. Steppers should be banned from being used in mounts.
                            I just don't enjoy balancing things every evening so it is not in use anymore.
                            w7ay I have come to the conclusion that with asiair and the zwo mount that no matter what you do in regards to duration and aggression and other setting changes, the inferior choppy PE in some mounts cannot be tamed consistantly or reliably especially by the whacky phd2 implimentation in asiair. It is best to say it is possible to get 0.5 but some of the time all hell brakes loose randomly anyways where the bad machining is evident. I will apply what I have learned one day to a better mount. I agree the rst135e is probably best for visual or when guiding is not required.
                            w7ay As to autoguiding, using 2 FPS guide camera,using the parameters that I had discussed here before (max step of less than 100, aggressiveness of less than 25%
                            Not sure if you saw my experiments but at least on my AM5 with PHD2, the max step didn’t seem to make much of a difference but lowering aggressiveness definitely made things worse. I assume this is because you have lower deviations in the higher harmonics on your RST? In analyzing my logs at least I could see that the mount was consistently behaving like it was resisting corrections especially in RA and the more frequent aggressive/large corrections helped it to get back on track.
                              eyecon I assume this is because you have lower deviations in the higher harmonics on your RST?
                              Donno. I don't use ZWO mounts, and do not recommend them, no matter what price.
